GX-65 Works on D-100/HS-34
bmarvel
Grand Junction Colorado
Just wanted to give you an update on something that I thought was still unknown. I just finished installing the D-100 and HS-34 in my RV-8A. The inputs to the HS-34 are an SL-30 and a GX-65. The SL-30 has already been known to be compatible (but I still have an issue I will post separately). Went up today after playing with some settings and can confirm the GX-65 also works fine on the HSI display portion of the D-100.
The settings I used for the GX-65 in the HSI setup window are:
Input--aviation
Output--none
Baud rate--9600
I assume this means all of the other GX versions will work too.
Again, this was with the GX-65 wired via the HS-34. I do not know if wiring the GX directly to the D-100 will also work.
Thanks! We've added your info to: http://wiki.dynonavionics.com/GPS_Serial_Compatibility_and_Configuration_Settings
lgingell
what did you use on the gx65? Mapcom or movmap? ...or something else?
do you know the OS software version of the GX65?
..lance
bmarvel
My GX-65 channel 1 is set to transmit mapcom and receive nav. The latest software upgrade I had was several years ago and I show it as 3.5. If there is something newer out, I don't have it.
