skydancer
RV-7 O-360 CS Prop. Dual Skyviews/AHRS. TruTrak AP
I'm having a lot of problems to get both ADAHRS to agree with each other!!!
When I had ADAHRS-200 out for repair and ran only single ADAHRS-201 in the system, I was able to calibrate the heading within +/- 1 degree.
But when I have dual ADAHRS in the system, I could never get both ADAHRS to agree with each other.
Following were my test results, each ADAHRS was calibrated at the Airport Compass Rose:
1. After the calibration with ADAHRS-201 and manually activated ADAHRS-200, the heading shows normal, but when I switch to ADAHRS-201 and have it activated, the heading would be off > 10 degrees.
2. If I calibrate the compass with ADAHRS-200 and manually activated ADAHRS-201, the heading shows normal, but when I switch to ADAHRS-200 and have it activated, the heading would be off > 10 degrees.
So the result shows ---
Calibrated 200, activated 201 ---- normal
Calibrated 200, activated 200 ---- abnormal.
Calibrated 201, activated 200 ---- normal.
Calibrated 201, activated 201 ---- abnormal
The above test were pretty consistent.
Any one has the answer for that? Your feedback will be greatly appreciated.
