We're in the prossess of installing this probe onto our flying club RV9A.
Had to install the probe inboard of the aileron bell crank/rib to mitigate interference with the left wing tiedown rope.
We'll be running white PVC water conduit which has a slightly larger diameter than the grey/orange PVC electrical conduit and actually weighs less. There is more than enough room in the white stuff to accommodate both pneumatic lines and the electrical wiring to/from the heater, and then some.
The conduit needs to be installed as three seperate sections so they are short enough to feed through the inspection ports. We are choosing not to interconnect the three sections above the access covers but there is certainly scope and connectors available to do so.
We're attaching the conduit to the ribs using P/N "LHMS-S5-D" cable holders pop-riveted to the rib lightening holes.
In our application we're faced with the challenge of potentially connecting all of this behind rib in dark places. :-/
I'm not thrilled at the idea but I suspect we'll have to cut the aluminium probe lines and install a second set of AN fittings to allow "dropping" the probe down through the gretz mount to connect/disconnect, although I can foresee interference issues with the control column-to-aileron bellcrank interconnect rod and the upper edge of the gretz mount if we're not careful how we bend the lines back.
Constructive criticism welcomed.
