High Fuel Pressure Warning
dahugo
Flying D180 with IO320 and supplied sensors from Dynon 6 years ago when i bought the unit. Over the last several flights i get a high fuel pressure warning--no rhyme or reason--sometimes on climb out, sometimes in cruise, and sometimes at idle over the numbers. Sometimes it lasts 10 seconds but sometimes several minutes.
I dont believe i have anything wrong with the engine. Have had similar issues with egt probes (which i replaced) and oil temp sensor (also which i replaced). As variation is independent of rpm this is most likely a sensor issue, yes?
What is the part number for the new type sensor?
Definitely the "most likely" cause, though you'll need to replace the sensor to be sure. For an injected engine, you want the 50 PSI Kavlico sensor, which is p/n 101716-000.
