I am considering buying an LSA aircraft powered by the HKS 700E engine. Need to know if the electrical output of this engine is sufficient for powering the Skyview 7" system with these modules....ADAHRS/EMS/Xpndr/Com/GPS.
Following is what I could find that describes the HKS 700E electrical system.
RMM
HKS 700E 60hp Engine==
Ignition System Dual CDI (Capacitive Discharge Ignition)
Generator Output AC-12Volts 210Watts
Regulator/Rectifier Three Phase Regulator
Starter Electric Only
• The electric probe .......This does draw from the available electrical power. If running strobes, nav lights, transponder, com radio, etc. it may not be possible to maintain a positive charge rate. (17.5 amps at 12V)
What are the DC toggle switches for?
• The HKS uses a DC CDI. It must have 12 V positive supplied for starting. Once running, the integral alternator will power the ignition if battery fails. Regardless, the ignition switching circuit must be closed for operation and open for shut down. .......With the reg rec and ignition lead wired to the IGN terminal, 12V+ is supplied for ignition via the battery when the key is turned to on or start position and via the integral alternator regardless of key position.
RMM
