Hobbs
Topgunul
Germany
Hello, is there any way to adjust the Hobbs and the other Timers in case after changing the dynes. In my case, i switch from normal to touch after 15 hours. Thx for help
Torsten
rvator51
Peoria, AZ
If I remember correctly; to modify the hobbs total time field, its something like:  Go to setup menu then EMS setup then engine information, then change the hobbs field to the new time and save it.  If that doesnt work, check the Skyview installation manual for the correct path.
As rvator says, it's in the engine info area in setup. You can just spin in whatever numbers you want.
