derstand that the AOA system watches the two pitot tube ports and when the AOA tube port becomes more and more exposed to the airstream it will corolate that indicated pressure to the pressure that was seen during the calibration flights and indicate a stall.
The question I have is how does the ADAHRS input correlate with this second pitot port pressure?
I am installing this AOA system in a Velocity (canard) airplane and the advantage of a canard airplane is that the "stall" is so gentle that it is more like a mush because the canard (front wing) will only nibble at the stall and the nose does not really lower it just sort of viberates as opposed to the traditional stall with the nose lowering sharply. Should I then knowing this feature of the canard airplane fly the calibration flights and when I know that front wing is going to mush stall should I push the stick forward to trick the system and make it think that is the stall point?
If the calibration flights are all made with wings level what happens during a steep turn? In other words if the calibration flights were all done at wings level with only one G then what happens let's say on a turn from base to final when the airplane is in a 30-degree bank?
