aceflyingservice
- Joined
- Nov 10, 2005
- Messages
- 65
My question concerns the HS34 and the consequences of an electrical power failure. If a panel with a Garmin 496 (which has an internal battery backup) that is hooked directly to the D10A (which has an internal battery backup) experiences total electrical failure, both of these units would continue to work, with the 496 delivering navigation data to the D10A HSI. What happens when the 496 is connected to the D10A thru the HS34 and the aircraft experiences electrical failure. Does the navigation signal pass thru the HS34 to the D10A, allowing the HSI to function? If not, is there a way to power the HS34 from the D10A internal battery? Thank you.
Roger Johnson
Long EZ N34JR
Roger Johnson
Long EZ N34JR
