Warning - the following is highly specific and very sleep inducing!
I have finally gotten around to installing a Dynon HS34 so that I can display my GNS430 WAAS GPS signal and also the 430s VOR/LOC/GS signal on my Dynon D10A. The problem is that the ARINC 429 and SDI settings that the HS34 needs from the GNS430 are a bit different than the settings that the GDC34A Data Converter/Chelton needs from the 430 that enables the Chelton to display the VOR/LOC/GS signal from the 430.
Specifically, in the GNS 430 setup on the "Main AIRNC 429 Config" page, the HS34 wants the following settings:
In 1 : High | EFIS / Airdata
In 2 : Unused by the HS34, configure as needed for other equipment
Out : High | GAMA 429
SDI : Common
but the GDC34A Data Converter/chelton wants the "Out" to be "high" and "ARINC 429" I know ARINC and GAMA are similar but does it matter whether I use GAMA or ARINC as the setting? Does anyone know if the the GDC34A/chelton will accept a GAMA429 signal and/or will the HS34 accept an ARINC signal. The SDI on the Main ARINC 429 config page for the HS34 wants to be common. I don't think the Chelton cares about this as it is GPS output from the 430 and the chelton doesn't take any GPS data from the 430. Does that sound right?
OK the next issue is the "VOR / LOC / GS ARINC 429 Config" Page on the 430. The HS34 wants the following
TX: High
RX: High
SDI: Common
DME: Unused by HS34
the GDC34A/Chelton wants the GNS430 "VOR / LOC / GS AIRNC 429 Config" Page
TX: High
RX: unused by chelton
SDI: VOR/ILS 1
DME: unused
Does anyone know if the SDI setting of common for the HS34 will screw up the SDI setting of VOR/ILS 1 for the GDC34A/Chelton?
OK phwew ... that was alot.
Tom
SDI : Common
TX: High
RX: High
SDI: Common
DME: Unused by HS34
TX: High
SDI: VOR/ILS 1
DME: unused
Tom
