HSI vor bearing pointer
floydwilkes
I recieved my replacement D-180. With the old unit, the vor bearing pointer worked. With the new one, it does not. I do not know what I have done differently. This is a D-180, HS34, Garmin 430 setup. Any sugestions for the proper settings?
BTW, the old unit was dropped of at UPS today RMA5142
Floyd Wilkes
Have you pressed BRG SRC then turned the value knob? I bet you just don't have a source selected.
Alternately, you don't have the VOR talking to the HS34 for some reason. Make sure you have a NAV source set up in ARINC.
floydwilkes
I have pressed the BRG SRC but did not turn the knob. I will try that.
The VOR course works when you hit the NAV source button so I know it is talking to the VOR part.
I will let you know if the above works. Probably will.
Floyd Wilkes
floydwilkes
It worked. Quess I should try reading the directions more often.
Thanks again.
Floyd Wilkes
