You might have to experiment a little. Here are the instructions from page 7-39 of the SkyView System Installation Manual (Revision Y, dated April 2016.)
Tachometer Transducer
If you have a dedicated tachometer transducer (usually with a 12 volt output), you may simply connect its output to the Standard RPM Left input on the SV-EMS-220/221. Ensure that you follow all recommendations given in the manual for your individual tachometer transducer. P-lead pickoff (Lycoming and Continental) If you do not have a dedicated tachometer pickoff, you must follow the instructions below.
Use the two included 30 k[ch8486] resistors (color bands: orange, black, brown, red, brown; connect in either direction) to attach left and right P-leads to the standard RPM Left and RPM Right inputs on the SV-EMS-220/221. Connect them as shown in Figure 50. It is important to connect each resistor as close as possible to the spot where you tap into the P-lead. This minimizes the length of cable carrying high voltage spikes.
Six-cylinder Lycoming engines sometimes need more inline resistance to prevent false readings by the SV-EMS-220/221. If you supply your own resistors, they need not be exactly 30 k[ch8486]. Additionally, both 1/4W and 1/2W resistors are cceptable to use.
Figure 50 – Magneto Pick Off
If, after setting the PULS/REV R and L values as described in the Engine Information Section, you see unstable RPM, you may need to increase the series resistance. We recommend increasing the resistance in increments of approximately 30 k[ch8486] – approx. 30 k[ch8486], approx. 60 k[ch8486], approx. 90 k[ch8486], approx. 120 k[ch8486], and approx. 150 k[ch8486]. Try each value in sequence. A higher resistance value is not necessarily “better”, as too high a resistance can reduce the amplitude of the RPM signal to the point where you may see no, or low, RPM.
