Hi All,
Help needed! On our first flight the MAP was under reading on the D120. We have a woodcomp sr 3000 2 blade VP prop and Rotax 912ULS.
On the ground it reads 21 inches with engine switched off, I looked in a Cessna 182 beside our aircraft in the hangar and it's MAP gauge read 29 inches. When airborne at full power only about 19 ½ inches, throttled back at about 5000rpm it reads 17 inches.
It’s set up on sensor 1 at the moment which doesn’t seem to have any scope for adjustment. I noticed in sensor 2 that there are two settings that you can vary AUXSF and AUXOFF. What are these settings for? Can I use sensor 2 ?
Can you tell me how I can use AUXSF and AUXOFF to get the indicated MAP to be correct for my D120. I'm able to get an accurate QNH and QFE as there is an Airport close by and I know the exact height of my hangar.
Really want to get this fixed so we can carry out the test schedule asap
Thanks Guys
David
Thanks Guys
David
