Indicated voltage
jgreen_sg
Flying is great, but I really like building!
Vancouver Island BC
Been using my HDX with EMS for a while.
The bus voltage now suddenly shows Zero. Everything else is normal. Battery is fully charged. Where do I start to trouble shoot?
BlueCrab
Begin with your schematic... and checking that connectors are secure and tight to your EMS module, I assume an SV-EMS-220. Bus voltage should be on pin 1 of the 37-pin connector that feeds the EMS module.
MikeD
KPYM
What are you seeing for amperage when this occurs?
Check all your cables. Make sure they are well seated.
Pins 1 & 2 on your EMS harness is where voltage is measured. Pin 1 is typically your main bus voltage, pin 2 would be for a custom point.
Measure the voltage coming into pin 1. If it’s not 0 call Dynon. Most likely an EMS issue
