inputs on a D180
Rv9er
Can I use one of the 3 GP inputs on a D180 for a voltage 1-5 input? Most of the installation manual is using those for thermocouples or resistive inputs. Also read something about having to have a HS34 module to use those inputs ports. Not sure what that's all about. I am planning to use a FlightData L2e adapter to indicate engine Timing degs on my D180 if that GP will accept a 1-5 vdc signal. The module is marketed as a Electronic Ignition to EFIS adapter. Thanks for your help.
Yes.
Those are only menu configuration options you'd use if you have an HS34 installed. It only affects the way the system uses the inputs on those pins. It doesn't affect the pins themselves.
