HRII_Pilot
- Joined
- Aug 2, 2007
- Messages
- 3
Where do I start. I have had My D180 on my HRII for 27 hours now and am having some intermittent faulty readings. The problems starting occuring arround hour 15. I am not sure the unit is the problem. I am in hopes that someone in the forum will have some suggestions. The problems are:
Fuel Flow will go from 16gph to 0 then back to 16
Low current alarm. reads -99amps then slowly climbs back to +2amps
High EGT alarm. all 6 cyl. jump to 1500+ then decrease to normal
High fuel pressure alarm
Low fuel pressure alarm
High oil pressure alarm
low oil pressure alarm
These alarms are very random but always start with the fuel flow going to 0 and progresses to the others. They also do not occur till 5 to 10 minutes after takeoff. Makes me thik it is heat related. I have checked all electrical connections including the grounding system and all are good. Per Dynon tech support, I physically removed the fuel flow to see if it was the source of my problem. It wasn't. With the unit acting up, I switched off the breaker to the unit and ran it on battery to see if the alternatior was the problem. It wasn't. I'm out of ideas and any suggestions would be greatly appreciated.
thanks
ken
thanks
ken
