vlittle
- Joined
- May 7, 2006
- Messages
- 552
I'm struggling to get the correct resistor value for my IO-540-D4A5. Initially I used 30K, but I got spurious prop overspeed alarms, so I wired in a trimmer potentiometer, accessible in flight.
I can eliminate the spurious overspeed warnings, but now I get spurious dropouts in the rpm indication at low rpms (around 1500 and below).
The sweet spot is eluding me.
I have an electronic ignition on the right, the magneto is on the left.
It would be very helpful if you could publish the input structure for the EMS standard rpm input. This will help me establish the correct resistor value (or other circuit) to minimize this problem.
P-lead waveforms are dependent on the magneto, rpm and spark plugs. I'm using REM37BY, as recommended by AeroSport, but on not on the Lycoming list of approved plugs. Excessive ringing could make things worse, but I think an AGC circuit up front would take care of this. I presume that the SV does not use an AGC for these inputs, but it's easy to add one externally.
Thanks, Vern
Thanks, Vern
