Jeppesen data not showing
Janekom
South Africa
Someone with two legacy D1000 screens asked my advice. The Jeppesen Aviation and Obstacle data base shows installed but there is absolutely nothin displayed on his maps. Just the default Dynon base map. Is there any setting you guys can think of that should be changed or is the Jeppesen data maybe corrupt?
Is it selected as a MAP LAYER in MAP CONTROLS? It won't display otherwise.
Janekom
South Africa
Yes non US. Actually South Africa and here we buy the Once off Africa Aviation and Africa data base.
Malndi
Is the Jepp data on a USB? If so, try reseating it after the SV has booted up.
Janekom
South Africa
OK the solution was to ask Jeppesen to supply new files for download. Downloaded it to a flash drive and re loaded at the aircraft. Now working perfectly. I assume the previous attempt went corrupt somehow.
