Kavlico fuel pressure sender
davejohnson
I am installing a ULPower 350Is (injected) and have the Kavilco fuel and oil pressure senders. When I run the electric pump (either of them) I get a pressure reading of 11psi, it should be around 35psi. My first thought was that I had swapped the oil(150psi) sender with the fuel(50psi), but have checked them and they are the right way around. Any suggestions as to what is wrong?
Dave:
Which of our EMS systems do you have?
Did you configure the EMS to specify that you have the correct sensor type?
BlueCH750
Low and Slow
Dave,
Did you ever figure out your issue? I'm starting my sensor installs and wiring now on my UL350iS...Thanks!
