Landing Gear Warning
thibault
Just installed circuitry connected to the EMS contact pin  for gear warning.  This works very nicely, BTW.  I used a tiny circuit board and a few parts so that the warning is turned off only if all three gear are down and locked.
FEATURE REQUEST:  Make the "Check Gear" audio call out more than two times once triggered.  Make it every "N" seconds or "M" knots slower, at first, and then more urgently as the aircraft continues to slow down, with the gear still not down and locked.
Dynon101
I love flying!<br />
While searching for a solution to my gear warning voice concern I discovered this post and it appears to answer my question.
Right now the CHECK GEAR will only repeat twice however the GEAR OVERSPEED will repeat continuously.
Is it possible to have the system repeat "CHECK GEAR" continuously when the gear is not down and the IAS is below the threshold? Having it repeat only twice can lead to negative consequences so having the lady repeat it until the gear is down would be best.
