Lean Mode
TJRV8
When I select the "Lean" mode and pull the mixture, my CHT/EGT display will show when each cylinder peaks and the LOP delta from peak. Should it also show the delta from peak if I advance the mixture to ROP? It always reverts back to the actual EGTs. As I read the manual it seems as if it should show the deltas from peak for both LOP & ROP.
preid
SoCal
Usually I reset the LEAN after completing a ROP to LOP and getting the bottom EGT number and do it (from new start) from LOP to ROP.
I would assume that the LEAN feature is looking for the PEAK before "kicking in" so it would make sense if it did not work in reverse since its designed to get either LOP or ROP from PEAK.
Have you tried resetting when going from one extreme to the other? If not try that out and see if it works as you expected.
Let us know if that didnt resolve the issue.
P
