Hi There:
Here is my setup: 2 HDX 10”, Garmin GPS 175 and a Garmin SL30. Arinc 429.
I have been trying to get the Dynon Autopilot to fly via a GPS set course on the 175 until the final approach course (say via vectors), then have the HDX auto switch to the nav 2 signal, which in this case happens to be the SL30 which would be tuned to the local localizer frequency.
Problem 1:
I am not able to get the HDX to AUTO SWITCH. I did set the value to YES (Label 1000P) in the Arinc 429 setup. By the way my Arinc 429 shows only one NAV source which is the GPS 175. When I try to add a NAV 2 source for the SL30, which I think is set up as serial port 2, it shows up RED and does not bring up the label. Not sure if that is the correct setup or not.
Problem 2:
Because the auto switch does not happen when i hit the FAF of an ILS approach, i switch the NAV 1 source on the HDX to the SL30 (which has the localizer frequency tuned in) manually. I get the glide slope indicator, but for some reason the localizer seems to be off. It shows the plane to the right of it, and if on AUTO Pilot, the plane starts to turn to the right trying to intercept the localizer even though I am looking straight down at the runway.
My local avionics guy thinks we need to calibrate the SL30 but from what I am reading online, that thing is bullet proof and hardly ever needs to be calibrated.
What am I doing wrong?
Problem 1:
Problem 2:
