Loss of touch screen capability in flight
lavallejd
2W6
Here is a new one that I think maybe heat related.
On a sunny hot afternoon in Charleston, SC, started the plane, system up and running, went through my screen generated checklists and proceeded to start my take off. After climbing out through 400 feet, went to touch the screen and no response. touched the HSI select and nothing. screen reponsed to LSK commands but no reponse on the screen. Screen was stuck on half screen mode forhte EMS so I had to use the other display for engine monitoring. Other display worked just fine.
A week later, on another relatively hot day (+90°), screen lost touch command capability again while on the ground. This time I recylced the circuit breaker and everything came back up with no issues.
Is there an operating tempertaure limit?
Should I be concerned?
Should there be an emergency procedure for this condition? In other words, in flight are we allowed to recylce power to the displays?
The display specification (Page 2-8 of Document 101320-037, Revision AL) that it was certified to DO-160 Category A (though it should be C if claiming 35,000') with an operating temperature between -30°C to +60°C. So above 140°F, display functions could fail? With the cockpit baking at 95° temperatures it maybe possible to see 140°+ temperatures (aggravated solar). Has anyone else experienced this anomaly on hot days?
If this condition is resettable once ambient temperatures are within tolerance, an auxiliary cooling fan maybe needed instead of an RMA back to Dynon.
So here we are 4 years later. Issue had been intermittent over the years and no longer temperature related. Resetting the display cured the problem… until mid year 2025. The right hand side of the screen in the middle completely lost its touch function. You know, that critical area under airport Info page for where you need to select wx or plates. So the plane went into annual this month, I’ve pulled the HDX1100 and RMAd it back to Dynon for repair. Still waiting on prognosis and cost. Fingers crossed they find the problem.
Thanks for the update. Keep us posted. Followup posts like this often help folks down the road here.
Here is the latest update… oh boy am I happy
The LCD/touch driver was failed, so some bad hardware unfortunately. They replaced the LCD screen and the baseboard which is associated with some of those connections with a newer and more improved version.
After thought, they did not charge me anything beyond the std shop fee (which by the way is cheaper than Garmin). Customer service was terrific and they kept me up to date. For those wondering, I bought the system back in January 2020 and the touch problem started in 2023/2024. Can’t wait to get it back in the plane and fly, fly, fly!
