I just installed a new Dynon Manifold pressure sensor on a D180. First issue is that it reads 27.7 in with the engine off while the actual pressure was 30.4 in. I am used to mechanical gauges that are within a needle width of actual.
Just how accurate should I expect this to be? I would think almost 10% off is a bit much.
Also, even given the error, the wide open throttle it only reads 23 inches add 10 % and that is 25 in, which is still a bit hard to believe. Is there a set of rules about the location for the pressure pickup location? There was no place for so I had to make one.
