Map and FPL Simul Display
jc2da
The other day I was surprised that this particular screen config was not possible on a 2 screen setup.
1. Currently, when pushing FPL button from 20% EMS, 80% MAP SV goes to 50% EMS, 50% FPL. MAP disappears entirely. This is quite strange to me. Why not go to scenario #2 below.
2. Instead, I want SV to keep 20% EMS and show 40% MAP and 40% FPL. This is my expectation and would give much better SA than removing the MAP entirely.
3. If you start with 100% MAP and push FPL, you get 50% MAP and 50% FPL. Thus, it is possible to show MAP and FPL simultaneously, but only if you start 100% MAP.
The other irony to this, is that the 50% FPL display is actually setup to use only 40% of the display already. It just fills in the space with a blank column.
Thus, it would seem like a fairly simple change to support my scenario #2 above.
I hope you consider this fairly "minor" change!!!
I love aviation!
I suspect you are pushing the wrong buttons. I fly with 40/20/40 on my SV1000T, which is PFD/EMS/MAP. This is set using the Screen and Layout options/buttons.
FPL is related to Fight Planning.
Sounds like he's confusing "PFD" with "FPL" :)
PFD: Primary Flight Display
"If you start with 100% MAP and push [PFD], you get 50% MAP and 50% [PFD]."
Yup. Precisely as you should.
jc2da
No, I meant what I wrote in original post exactly as written.
I want exactly this: 20% EMS, 40% MAP, 40% FPL or Flightplan.
IE, this is exactly how the G1000 MFD works.
Wow, this is pretty funny. I found this image just now. Unfortunately, it is a SIM! Even these SIM guys understand the issue and implemented their own custom screen!
https://www.mudspike.com/aerobask-epic-e1000-skyview-v2/
I am trying to understand why the above display is not possible? 20% EMS, 40% MAP, 40% (FPL, INFO, Nearest, etc.) This layout is perfect but not possible, outside of the SIM.
You said:
"Currently, when pushing FPL button from 20% EMS, 80% MAP SV goes to 50% EMS, 50% FPL. MAP disappears entirely. "
If you are really doing
Main Menu-MAP followed by MAP Menu-FPL, it's doing exactly what the user's manual says:
FPL
Press FPL (Flight Plan) to bring up a window that can be used to create, display, or modify a Flight Plan. Reference the Flight Planning section of this guide for details.
Flight Plan Window
Press the FPL button in the MAP Menu to open the Flight Plan window and menu. The Flight Plan window contains tabs of available flight plan sources
etc.
Once you create a flight plan and activate it, isn't it shown on the Map?
krw5927
I certainly wouldn't want my flight instruments disappearing on my only display while I view a flight plan.  Perhaps if you have two displays, and designate one display as MFD...
I love aviation!
Now I understand. It was not at all clear what you were trying to do from your first post.
jc2da
I certainly wouldn't want my flight instruments disappearing on my only display while I view a flight plan.  Perhaps if you have two displays, and designate one display as MFD... «
Yes, this on a dual display setup. I reviewed all the menus and manuals and could not find anything that would fix this. I even reviewed HDX manuals, and it seems to be the same as Touch.
I find it hard to believe this is an oversight that nobody noticed before. Is this a bug?
Yeah, sorry. I realized a picture is worth a thousand words. However, the SIM screenshot above is exactly what I wanted.
Also, it defies logic that a 20% EMS, 80% MAP screen goes to 50% EMS, 50% FPL. It seems logical to keep 20% EMS and split the MAP side into 40% MAP, 40% FPL, right?
I love aviation!
I don't use the FLP screen much so I hadn't noticed the behavior. Most of my FPL updates are done on my phone in FF and transferred to the SV over wifi.
An email to Dynon support might be helpful to see if this is expected behavior.
This is expected behavior. The only time that you'll get a flight plan/map split screen in SkyView Classic and Touch is when you're full-screen map. Some of us here would like what is depicted in the sim above, but there are deep technical constraints in those systems' windowing and UX subsystems that make this harder than we wish it were.
jc2da
Dynon, appreciate the reply. Totally understand. The reality of tech sometimes.
I am training for my IFR, hence I was trying out slight variations in screen layouts. I realize now that I am fine with the screen setup I have. No need for changes.
Enroute:
PFD: 40% MAP, 60% PFD or 40% PFD and 20% EMS
MFD: 20% EMS, 80% MAP
Approach mode:
PFD: 40% PLATE, 60% PFD
FPL edits are mostly made on the PFD, and I can review the big picture map on the MFD simultaneously. Hence, I still get the functionality that I want.
Thanks for the update!
jc2da
However, I think the same behavior occurs when viewing the INFO page as well. I would think you would regularly use INFO page, even with wifi for METAR info (with ads-b in), frequencies, runway layout, remarks, vors, etc.
I love aviation!
Yes, it does hide a lot of the screen when viewing INFO, which I use often. Not much you can do about that, IMO. Having dual screens makes it a non-problem for me.
jc2da
I do have dual screens, but it would still be beneficial IMHO. ;) Several cases.
NRST airport in case of engine out. Do you want just a list of bearings or would be nice to see them SIMUL on MAP, too. Having MAP and NRST shown right next to each other is ideal, especially in emergencies.
Tracking VOR's, where you want FREQ's shown with the VOR ID. Referring to MAP and NRST VOR's is useful, too.
Verifying waypoints on your FPL while IFR. Moving your head too much is dangerous while IFR.
