Missing PFD page?
dougnlina
I am assembling an aircraft with a dual 7" Dynon system installed. When I boot the system up, neither screen has the PFD page on it, and there is no button on the screen menu to add it. The wings are currently separate from the fuselage, and the ADAHRS is in one of the wings, however, I SWEAR that I was able to get the PFD page on the displays before without the ADAHRS module hooked up, it just had an error message and a big red X through the window. Is the PFD page eliminated when the ADAHRS is not hooked up? As additional information, the displays have been updated twice without the ADAHRS attached, and the plane is in a shared hangar where others may have?? played with the display without my knowing it. Is there a setting that turns the PFD page off? would it do it to both screens? What am I missing here?
Thanks, DP
The PFD page isn't eliminated when you disconnect the ADARHS. However, it IS if the system doesn't think that there's an ADAHRS installed. That can happen if you do a network configuration without the ADAHRS connected, or if you do an update in the same fashion. Once you have everything connected again AND do a network configuration, SkyView will find the ADAHRS, offer to upgrade it, and then you'll be back in business.
