Modify active Skyview route from EFB?
RexBrewer
Do changes to a flight plan in FlyQEFB made while flying (VFR) change the active flight plan in a WiFi connected Skyview? Can one keep the autopilot connected to the Skyview while modifying the active plan? Can the route being flown be modified by changing the connected FlyQ EFB? flight plan?
The flight plan does not update or sync in real time. But you can certainly re-send it to SkyView from FlyQ EFB after modifying it there.
midlifeflyer
North Carolina
...which makes sense. You may be doing a "what if...?" in the EFB and don't want it to automatically sync,
RexBrewer
I see the FlyQ exports to the flight plan only when export to WiFi Skyview connection is selected. A little practice made it easy.
I am still unable to get the skyview to recognize the WiFi connected FlyQ iPad as a data source for chart updates while in the skyview setup menu. Skyview says “searching for WiFi” while the iPad is WiFi connected and 2 way communication with iPad/FlyQ is working.
