rogersmart
- Joined
- Aug 4, 2008
- Messages
- 109
I am building an RV-8A and planning on using the new generation system, hurry up! I have some questions for panel planning and placement of modules.
1. I would like to know if I got this right. For a system with 10” screen, autopilot, moving map and EMS, the modules will be the Display, EMS module mounted remotely (inside the firewall), AHRS or ADAHRS mounted remotely, a GPS antenna/receiver and servos mounted in proper locations. Is this correct?
2. Is the AHRS or ADAHRS module going to include magnetic heading internally or require an external module like the EDC-D10? Will there be a restriction on mounting adjacent to steel parts, strobe power supply, strobe wiring or adjacent to the autopilot servos. Can it be mounted behind the panel near a radio? What is a safe distance from these items. Please give some guidance.
3. Will EMS, ADAHRS and GPS modules be powered from the Display and use battery backup if necessary. It appears the servos will are powered separately.
4. Will wiring between the modules be 4 wire, 2 DSAB and 2 power? What type of wire will be used?, shielded, twisted pair? Will there be pre-made harness for connecting modules?
5. I see there is no tray, can the the display be removed completely by removing the 6 screws shown and unplugging some connectors? (how many connectors and what type?) Would this leave a big hole for access behind the panel, ie no mounting parts.
I have received a SV32 pitch servo and will be installing it as the first component. I plan to order other available items as I progress such as the engine kit and roll servo, Please share information as it becomes available so I can plan better and more accurately as our project moves forward and your new generation product plans become final.
