1) In order to have a larger number of Waypoints on my moving map , I have created with Google earth some more Waypoints ,
I have copied Waypoints on a memory stick (after they were converted to fills that can be read by the Dynon system)
Since I have two displays (10") I have connected the memory stick to both of them (one after the other) and imported the fills,
The first import ( to the first display) went well, in the second display I did the same routine and the system has confirmed that the new
Fills were add successfully… but the new Waypoints didn’t show on the screen and I see only the old one without the new Waypoints , I imported it twice but it didn’t help
What should I do ?
2) On the Google earth system I chose an Dot gray icon to show as Waypoints but on the moving map it shows a yellow pin? how can I change it?
3)I want to show on the moving map only the Waypoints that I add , how can clear the Waypoints that comes with your data base (middle east-israel)
In case I cannot do it, how can I know what Waypoints you have in your data base so I don't add Waypoints they are already in the data base
The reason for that is that a get sometimes double Waypoints when I add new Waypoint
What should I do ?
