ebke-zenith
Dear Dynon,
I have Skyview 1000 with latest updates installed. Skyview has started on one attempt in the past.
I am only preparing for test flight, so all experience has been in hanger or on ground.
Today on power up, things proceeded normally till Engine/Map/Flight screen disappeared after only being on screen appx. 10 seconds. The screen turned into blue or red screens, then dark blank screen. The script began appearing on left again and on to SV screen with the verbal announce of Dynon SV. The process repeated 4 or 5 times till Skyview finally successfully booted up.
I turned power off to see if powering up a second time would be successful, but same result.
I have a video from my sons phone, but could not figure out how to send.
During each startup attempt, in the upper right corner, SV showed NO DB and in the bottom of the Dynon radio, it said NO SV.
On final successful start up, NO DB disappeared from SV and the correct airport ID showed in bottom of radio.
SV worked several times in the hanger previous with no problem.
Any help to return to simple first time start up?
