No indication
PGLong
Helping a friend de-bug his Skyview D1000 On his EMS module, he shows no voltage and no oil pressure. Other items seem to work ok. Any thing I should look for? There is 12 VDC on pin 1 of the connector.. How can I test the oil pressure sensor. Is there a way I can show Hi pressure by grounding the lead to the pressure sensor?
Many thanks, Pat
I love aviation!
The MAP and Kavlico oil and fuel sensors require 5 volts. Only the fuel flow sensor (Red Cube) uses 12 volts. It is suggested to split the 5 volt output from the EMS (pin 18) to all three sensors.
PGLong
That's where the error was.........Thanks!
