No Yellow wire on my Dynon D10A Cable
globox95
Hi evry body, i just brought an EFIS D10 A and a Dynon Cable, it seems that there is no yellow wire for the keep alive power on it ! instead of that i see an yelow/green wire but i think it is for fhe GPS connexion.
thanks for your help
regards
Do not connect the 'keep alive' wire, it's not to be used anymore. The green/yellow wire is for the 'ground' for a warning light if you desire to have one.
globox95
The manual describe the yellow wire, it dont exist on my dynon cable, that's why i wrote this message
regards
My comment about the "Keep alive' (pin2) still applies, the install manual has not been updated.
The Dynon cable you mentioned may not have the correct coloured wires in the relevant locations - if that is the case it may be better to call out the pin numbers & describe what you want to achieve.
If you want to connect a Gps then use pin 22 on the Dynon.
HTH
globox95
Tanks Jake J for your answer
The pin 2 is not connectes on my harness
I Will Check if the yellow/Green is realy connected to the gps pin before connect it.
I found a post on an dynon ems harness wich have the same observation Than me on my harness. Is the dynon ems harness is the same Than the efis D10a ?
Best regards
globox95
Installation is done,
No yellow wire on my harness And no pin 2 for keep alive power installed.
The alone yellow/Green wire is for the gps connection
I dont know what is the black/white short wire on the harness
The White/Black wire is a connection to the shield of the cable to the EDC-D10A remote magnetometer - it's rarely needed.
