Non-dynon oil temp sender
n28et
Hello,
I am converting from a Rocky Mountain uMonitor which uses an AD590 temp transducer for oil temperature.  It has a linear current output of 1 [ch956]A/K (microamps per deg. Kelvin).  Is there anyway to configure this transducer with the Dynon EMS?  I was thinking possibly using pin 6?  Any help is appreciated.
Thank you.
Erich
On a D10/D120/D180, it's not possible. With SkyView it technically possible, but it's far from trivial. It's usually much easier to switch to one of our oil temperature sensors.
n28et
Hi Dynon,
Thank you for the quick response. While I have a Skyview, I don't need to take on a non-trivial task. I will go ahead and order a new temp sensor.
Erich
