Oil pressure and fuel pressure senders
LouRubin
I’m wondering if my senders are compatable with Dynon. I noticed my existing pressure senders only have a ground and a power lead connection. Do I need to replace the senders to the 3 wire senders with a 5 volt power feed , sensor wire and ground?
Some 12 volt sensors are compatible. What kind of sensors are they? Have you checked the table on page 23-2 of the install guide?
LouRubin
No idea what I have but there definitely not Kavlico Dynon senders.
My guess is no since they don’t have a 3 wire connection
Thanks again
GaryRay
Using your existing sensors depends on whether you want to step out of the box. Dynon provides turn-key sensor solutions that they support.
But they also leave the lid off the box for solutions that take a bit more work. Read this to help decide.
I chose this route and it works fine. All thanks to Raymond for sorting this out. I learned a lot in the process.
