- Joined
- Oct 6, 2010
- Messages
- 1,691
OK, this is weird...I finished a trip for Thanksgiving stuff, and after shutdown, drained the oil and started preparations for the annual inspection, fiberglass finish work (prepping for paint), etc. Let it drain for a day or three, then replaced the oil filter and filled it up. Haven't started it yet, as I've been doing the gazillion things for annual condition inspection, but....here's the weird part.
I had the system on several times, once for about 2-1/2 hours while I changed to Princeton fuel convertors and calibrated the system, etc. At one point, I noticed that my Hobbs meter on the SV had increased! It had added about 3 hours or so since I drained the oil after the last trip.
I looked at the data files in Savvy Analysis, and it looks like at some point the oil pressure went above 15 psi (and it's staying there, apparently, at least until I start the engine). It can be seen in several files, over a period of couple of weeks, going up a little to around 12, then up some more, etc., until finally over 15.
What could explain this? I never saw it before, because I always started the engine for leak checks immediately after filling it with oil.
I'm quite sure the sensors are okay...this must be some strange phenomenon
