In cruise today oil pressure suddenly began to fluctuate and then went to zero with red X shortly followed by fuel flow increasing to max. With both got audible caution warnings.
Engine continued to run normally. On descent with power reduced indications returned to normal but as power increased the faults returned.
Landing and ta I indications were normal and post flight oil quantity was as was pre flight and no other problems found after removing cowling (RV-12).
Subsequent start up, taxi, and run up normal. after lift off oil pressure warning andfuel flow warning returned and went away at low and reduced power.
Prior to flight I had uploaded latest routine software update from Dynon.
I discussed problem with my Rotax trained and qualified mechanic who suggested it was a Dynon issue.
Any ideas?
Any ideas?
