Oil temp sensor stud
Hey, what's the right "stack-up" for attaching the wire ring terminal to the stud on the oil temp sensor? Phenolic washer, ring terminal, lock washer, nut? (i.e., the ring terminal goes "above" the phenolic washer, or below?).
TIA!
Steve
There should be a metal washer in there as well.
First on to last on: phenolic washing, metal washer, ring terminal, lock washer, nut.
Thanks...I just looked real quick last night, I'm sure the metal washer is there, too, but will double-check tonight.
Thanks for the quick reply!
Steve
