I tried your steps RV8JD, I dont have any of the adjustments you show. Just the name of the sensor "100434-000"when selected. Maybe a newer firmware change? Im still on 16.1 version with older skyview.
15.2.0 | 1/4/2018 (version 54802) | Added: MAP adjustment. To use, adjust the BARO setting until the altimeter reads zero. The baro window is the current MAP pressure. Then, choose the appropriate MAP sensor in EMS configuration to make MAP as good as possible. |
sensor={
id=100434-000
;VERIFIED POLY, FILTER?
function=PRESSURE
pins=C37_P26
; THIS NAME IS FOR A SPECIAL CASE FUNCTION WHICH WILL NOT APPEND "PRESSURE" TO THE END OF THE SENSOR NAME
name=MAP
;The below are in PSI, not inHG, like all pressure senders
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7993
c_x0=1.1599
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high_resistance=NONE
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (-0.1)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7800
c_x0=1.1560
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (-0.2)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7608
c_x0=1.1522
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (-0.3)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7415
c_x0=1.1483
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (-0.4)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7223
c_x0=1.1445
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (-0.5)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.7030
c_x0=1.1406
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (+0.1)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.8186
c_x0=1.1637
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (+0.2)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.8378
c_x0=1.1676
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (+0.3)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.8571
c_x0=1.1714
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (+0.4)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.8763
c_x0=1.1753
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
sensor={
id=100434-000 (+0.5)
function=PRESSURE
pins=C37_P26
name=MAP
min_val=2
max_val=29.5
resolution=1
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=5.8956
c_x0=1.1791
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
You'd think that would be in either installation manual or the user's guide, wouldn't you? If it is, I couldn't find it. Thanks for the link!It looks like the MAP adjustments came with v15.2.0 on 1/4/2018. So you appear to have a pre-adjustment version of the EMS Sensor Config file.
From: https://dynonavionics.com/whats-new-skyview-sensor.php).
15.2.0 1/4/2018
(version 54802)Added: MAP adjustment. To use, adjust the BARO setting until the altimeter reads zero. The baro window is the current MAP pressure. Then, choose the appropriate MAP sensor in EMS configuration to make MAP as good as possible.
