PA calibration
alainrac
Is there a way to calibrate admission pressure to match the altimeter when engine out? today, it was std on the altimeter (29.92) and it was more on the PA value... nothing in the manual it seems?
I don't understand the question. What is admission pressure?
preid
SoCal
I tried your steps RV8JD, I dont have any of the adjustments you show. Just the name of the sensor "100434-000"when selected. Maybe a newer firmware change? Im still on 16.1 version with older skyview.
preid
SoCal
interesting i don’t get that option.. wonder what else I am missing.
preid
SoCal
Thank you! I seem to definitely have an older version of .sfg. Appreciate you bringing that to my attention and the detailed reply with steps!
It looks like the MAP adjustments came with v15.2.0 on 1/4/2018. So you appear to have a pre-adjustment version of the EMS Sensor Config file.
From: https://dynonavionics.com/whats-new-skyview-sensor.php).
15.2.01/4/2018
(version 54802)
Added: MAP adjustment. To use, adjust the BARO setting until the altimeter reads zero. The baro window is the current MAP pressure. Then, choose the appropriate MAP sensor in EMS configuration to make MAP as good as possible.
You'd think that would be in either installation manual or the user's guide, wouldn't you? If it is, I couldn't find it. Thanks for the link!
