Pin callouts for GTN650 ARINC429 and Intercom 2S
compnz
New Zealand
Is there a list of pins or drawing available detailing the install of a GTN650 to the Dynon Skyview system - using the Intercom 2S and the ARINC429 and using the SV-COM-C25 as COM1.
Apart from what is in the SV install manual.
Arinc 429 is as per the SV install manual, no other wiring info needed for that.
Garmin GTN 650 as # 2 Com ---
Connector P1003 Dynon Intercom
Phone Audio HI pin 7 pin 8
Lo pin 18 *
Mic Audio HI pin 5 15
LO pin 20 *
Mic KEY (TX) pin 11 12 (switch)
refer to the note about the asterix (*) in the Intercom install manual.
HTH or PM me & I'll call you if you wish. :)
Jake J
You can make it either one, up to you. However if you have the Dynon as (displayed on SV) Com 1 you can use the database for entry of Com frequencies, that requires a current database but a lot don't do that here due cost.
Jake J
Fair point - the GTN 650 is one of those units that there is a significant installed base for, so we'll update the COM radio and serial connections sections for the GTN 650 in a future update of the SkyView System Installation Guide.
