Dave,
I believe the pitot heat status line (white wire) is an GROUND or NO GROUND wire...in other words the voltage output does not modulate.
The PITOT HEAT STATUS line (White wire) is grounded when the controller is turned off or not
functioning properly. The PITOT HEAT STATUS line (White wire) can be connected to an
indicator on the panel, whose other terminal is connected to Switched 12V
When the Heated AOA/Pitot Probe is switched on and functioning properly, the PITOT HEAT STATUS line will be open (not grounded), leaving the indicator light turned off (no current is flowing). The PITOT HEAT STATUS line (White wire) can handle a maximum of 1A current, so choose the type of
indicator carefully.
Check out page 5-12 of the AOA/Pitot Probe and Heated AOA/Pitot Probe Installation Guide Rev. D FOR ADDITIONAL INFORMATION.
DID I READ YOUR QUESTION CORRECTLY?
