Power fuse size D10 EMS
deborahj
What size fuse should I use for pin 1 on my D10 EMS. "appropriately sized fuse" on page 4-1 in manual does not help a newbee at electrical stuff. Thanks
I love aviation!
Here is what I found in the install manual, page 2-2.
The EMS-D10 system-wide power requirement is 8 watts typical and 10 watts maximum. On a 12-volt system, this translates to about 1 amp of maximum current draw. On a 24-volt system, this translates to about 0.5 amps maximum current draw. Normally, a 2-amp circuit breaker or fuse is sufficient.
deborahj
Thanks Ray, I suppose if I had read the entire manual(which I have just printed out) I would have found this answer. Sorry to waste your time. John
