Radio issue
davestephens
Looking for ideas, fitted my new 8.33 radio, and intercom (I used the skyview intercom cable) and the radio talks to SV screen, and can send frequencies to the radio etc. I can also hear Atc radio talk in the headsets and when I talk I can hear myself in the headsets (can turn the vox up and down and my voice comes and goes etc) but when I transmit they just say “carrier” only?
Can’t figre out how the microphone can be heard etc but not through the radio on tx
Dave
So if you can hear yourself, then at least the headset to intercom connectivity is good. From there, I'd start by looking at the connections between the intercom and the COM radio. If the PTT was connected (such that the radio was transmitting, which it sounds like it is) but the audio out to the radio wasn't making it, that could lead to hearing a carrier only.
davestephens
Im going to go and have a look today, I just looked at wiring diagram again and noticed the pin outs are completely different for the 25kh radio and both wiring diagrams are shown in the manual and look the same, as I was referring to an iPad with the manual on and flicking back and forth I might have got the aidio input on the wrong pin on the radio, fingers crossed that’s it!
skyboy999
Check each PTT also. If you are using headset connected to P1 but the 'P1' PTT is actually wired as 'P2' and vice versa, this would transmit carrier only as you describe.
davestephens
you got me thinking now....................
Went back to plane today, checked double checked, re-wired the com D connector to the drawing again (intercom end is SV pre-wired loom) and no go. One of the guys a few planes down turned his on so we could try it (on freq 123.450) hand he could hear me clearly but very quiet, he said if engine was running he would not have been able to hear me.
Now, PTT wiring... both PTTs in the plane come through on one wire so i took that (from memory directly to the radio) as this only has 1 input, so i dont believe it goes to the intercom at all
Could this be an issue??
Cheers for taking time to reed this!
Dave
If you're using our intercom, the ptt should be run through it as our instructions show. Our intercom then in turn sends a ptt signal to the radio. If you have bypassed the intercom's ptt circuit, that would definitely cause issues. Is this the Dynon 8.33 radio, or a different one?
davestephens
its the 8.33
I did it this way as the PTT cables are within the screened cable (intercom pre made loom) and run to the back of the plane for headset sockets. there is no provision for PTT cable back from there. i will have to break into the mic cables behind the panel to fish out access to the red wires, connect them to the PTT switches, then run the yellow (pin 12 on intercom) to pin 15 on radio.
hope that sounds correct
Dave
dbwindom
RV-8
Fort Mill, SC
I'd never be accused of being a radio expert, but I ran around in circles for quite a while during my initial Dynon SV install. I could hear other planes, but the guy in the next hangar said "carrier only". Checked wiring, plugs, Bought a new antennae with no improvement.
Turned out that a setting in the SETUP menu was set to zero...
I can't remember what it was, but somehow it got turned down.
So...double check your MIC, transmit and audio settings.
