re-startup
Rob
Australia
Hi, I have just started up my skyview I do not have any EMS wires connected but every thing else is except the wing servo , I only get on the right side a map of USA and EMS fail also ADHARS fail there is a red light flashing on all modules can you advise what I can do ,I have not loaded any data yet.
Cheers Rob (Australia)
K
KRviator
Guest
By startup, Do you mean you have you done the network config to force it to locate new modules - or connected everything and powered on the display for the very first time?
Rob
Australia
I have powered up for the first time I know realize I have to configure all the modules so will do that tomorrow and see how I go.
Rob
K
KRviator
Guest
That'll sort you out, Rob.
When you run the network configuration test, you may find a notification that some firmware needs updating. It may pay to grab the latest versions of the required files on a USB stick before you head to the hangar to avoid a 3rd trip! ;)
Rob
Australia
I did take the new updates with me and it all worked fine ,Where do you find a hex code for mode s transponder and I can not get the jeppeson maps to show up on the screen It says they are loaded but all I get USA
Cheers Rob
K
KRviator
Guest
The HEX Code will be provided by CASA on request, but you'll need to have a registered aircraft or at least a registration reservation first. Hit up aircraft.register@casa.gov.au if you've been assigned a registration.
I'll have to defer to Dynon about the maps, as I'm going to use PocketFMS eventually.
Rob
Australia
Maps and all are now working it took quiet awhile for the GPS to find itself here once that happened the maps were there, I have talked to CASA about the hex code so all under control .Many Thanks
