It's not that 3A is "enough"...the question is if it's *too much* for the wire size. That is, if the box faulted and started pulling more than the rated 0.1A, and went all the way to 3A for some reason like an internal short, would that 3A be too much for the wire size and cause it burn/melt/etc.?And 3Amps seems more than reasonable. CB sizes are not specified to protect the component attached to them, they are there to protect the wiring... And if Dynon says 3 Amp is enough ...
I suggest for any avionic power leads you stick to #20 wire. #20 wire will handle a short long enough to trip a 5 amp breaker. Also #20 is not as fragile as smaller gauge wires.It's not that 3A is "enough"...the question is if it's *too much* for the wire size. That is, if the box faulted and started pulling more than the rated 0.1A, and went all the way to 3A for some reason like an internal short, would that 3A be too much for the wire size and cause it burn/melt/etc.?
Depending on length, of course.22AWG wire will carry max 7 amps.
So a very short duration in excess of 3 amps will not harm the wire
