RF noise
Rick Moss
Hi all; I’m hoping you can help. I have searched the forum and seen many posts about RF noise, but none quite match my issue:
Whenever my Skyview is turned on, there is a constant hum heard through the headsets. It is not affected by adjusting the volume on the radio, and it is not breaking the RX squelch. If I pull the breaker on the SV, the volume drops slightly, but the hum remains as it runs on the backup battery. Turning the SV off completely stops the noise.
It’s a composite aircraft, with all grounds run to the same negative bus bar, itself connected to the battery via 4AWG cable. The Dynon and the radio receive power from 2 different busses, although these busses are connected together with a Schottky diode between (1 is for Essential Services,
Fitted system:
New SV1000 installation, with an existing Trig TY91 radio fitted, connected to the SV via a serial TX/RX and the Audio-out runs to the aux-in of the Trig.
I am using the intercom built into the Trig; this radio has performed perfectly for the last 6 years with the steam gauges.
I’d be grateful for suggestions of where to start!
Rick Moss
I have; neither make any difference.
I have now discovered that the hum gets louder as the screen gets brighter, and quieter as it goes dimmer.
I love aviation!
Try grounding the screen(s) directly to the intercom. If that doesn't help, contact Dynon support directly. BTW, I prefer all audio related grounds going to a single point/location that is then grounded to the main aircraft ground.
Rick Moss
They’re both grounded to the same bus bar; so within 2” of each other on the same piece of brass: would screwing them on with the same screw make a difference, or are you referring to linking the 2 grounds elsewhere? I presume this would create a loop, which I understand to be a bad thing.
Taigajoe
Hello Rick,
I have the same problem with SV700 connected to the auxiliary input (AF_AUX_IN_HI) of an radio Becker AR6201 . If I disconnect the auxiliary input or if I use DIM level above 15 then the hum disappears.
The radio and the SV700 are grounded at the same negative bus bar. I think the brightness of the screen is regulated by PWM.
And I have another noise on the audio output of SV700: I have an irregular crackling on the line. For my understanding are these spikes radiated by data packets transferred somewhere in the system.
Has anyone this irregular crackling too?
Stevec
Hi
I have a D1000 and D700 with the audio outputs connected to a PM1200 intercom. I found that I heard a background noise that I could not remove. All grounds go to a common point. I also read in the installation manual that connecting the units case directly to ground with a 16 g wire would help with electrical noise. Nothing seems to work. I have discovered using the isolate switch on the PM1200 removes the noise and reading how the switch works I am now certain that the noise is being introduced into the system via the audio lines from the Dynon units. However I don’t yet have a solution to the problem
I love aviation!
Not exactly. A ground bar/location for all audio related components that is then grounded to the central ground location/battery. No ground loop will occur.
skyboy999
I seem to recall this was a known issue some years ago and Dynon provided an EMI kit to help suppress.
I remember one for the EMS units, to prevent RFI from wiggling some sensors like EGT/CHT, but I don't remember one for the display brightness. Might have been before my time, I picked up my hardware in 2014.
Taigajoe
I installed this EMI kit several years ago. If I remember right than I did not had this massive crackling after installing th EMI kit. Is it possible that this EMI kit is out of order?
fastfred58
Did you ever get this figured out. My d1000 is doing the same thing . I turn the skyview off and the garmin radio works fine.
