Rotax 912 coolant temperature
CarlosQ
Hello. What do I need to change in the HDX if I changed and old 912ULS with the old cylinder heads for the a new one with the suffix -01 heads?
Im aware of:
-. SETUP MENU > EMS SETUP >DISPLAY COOLANT INSTEAD OF CHT
I have done this an apparently nothing changes
-. The labels on the screen doesn’t change. Seems that is necessary to edit the name of the sensor
-. In the layout editor, nothing changes, there is not a new sensor that states coolant temperature.
-. I assume that the gauge ranges for CHT and CLNT are different. I don‘t see any difference.
do I’m missing something? There is another procedure I need to follow? If so, where?
thanks
The only thing this should change is the word CHT to CLNT. Did you do anything custom with your pin mapping nomenclature? It does not inherently change the ranges - you'll need to adjust them yourself.
CarlosQ
I haven't changed any configuration but I can change the values if they are not the factory ones. What is the default nomenclature?
Thanks.
