ploucandco
- Joined
- Oct 27, 2008
- Messages
- 59
Hello, I just sourced a second hand EMS-D10 to replace my analog gauges for the ROTAX 914 in my plane. I have the following questions:
1. Reading the EMS-D10 installation manual, I understand that I need to select OTHER and not ROTAX as Engine Type. Reading further, I see that the added value of selecting ROTAX is to have oil ranges depending on the RPM. Basically these values/recommendations are the same for the 912/912S/914. So I don't see the point in selecting OTHER for a ROTAX 914. Maybe I am missing something?
2. Is the MAP sensor to be used the default Dynon MAP sensor?
3. Today, the fuel pressure is measured by an UMA N1EU07D differential sender. I understand that this one is not directly supported by the EMS-D10 but is there a way to interface it. Now that you have experience with this sender on Skyview, potentially you could suggest something.
Thanks, Jacques.
Thanks, Jacques.
