Routing harnesses , etc.
BlueCH750
Low and Slow
Hi Dynon
Starting to route my servo and ADHARS network harnesses from the back end of the aircraft up forward to the panel.  In addition; need to route flap power, pitot power and comm RGA400 cable from the back as well.
(1) Is it OK to "bundle" the servo and ADHARS harness together in the same conduit or path?
(2)  How much separation (if any) is required between the harnesses and the other "higher voltage" or potentially noisy items mentioned (pitot, coax, flap, etc.)
(3)  The D37F harness for the EMS220 is not wired for pin #2.  If I want the ability to monitor the voltage of another bus, in addition to battery voltage via pin #1 can I simple insert a pin and associated wire into the existing #2 position?  Seems like I can, but would like verification.
Thanks!
It is fine to bundle all the wires. You don't need to separate the data wires from power wires.
As you say, you can hook any voltage 0-36V into pin #2 and display that if you want.
