RPM and D-180
jbstok
In retrofitting a D-180 onto the RV-8 I recently bought, I'm a little confused about how to hook up the tach input.
The airplane came with a UMA 1A3-4 tach sender hooked up to an electronic tach.
The D-180 manual describes two different wiring scenarios for the tach input. I could (I think) use the UMA tach sender, or I can wire a pick up off the P-leads. My helper thinks we can use both since there are two tach inputs into the Dynon harness, but I'm wondering if that wouldn't confuse the D-180 into thinking the airplane was a twin and displaying two tachs on the EMS screen. I don't have a problem using the UMA 1A3-4 sender, but my buddy is more old school and wants to use the P-leads, despite losing the RPM during a runup on when the mag is switched off.
Is it possible to use both? Would that be helpful at all? Is the UMA 1A3-4 sender even compatible with the D-180?
rvator51
Peoria, AZ
I use the tach sender on both the D10A and the Skyview. Works fine for me and I dont worry about losing RPM when changing mags.
Regards,
Tom Velvick
Phoenix, AZ
jbstok
OK, thanks. We've decided to do both, using the sender and picking up off one of the p-leads. Probably get that done tomorrow.
Pugh@ctcweb.net
I am installing the D-180 to a Rotax 914. It appears there is a Tach output from the turbo control unit. Can this output (pin 13 on the TCU) be wired directly to the RPM Left (pin 32) on the EMS?
No smoke is good
Dick
