cjohngraham
- Joined
- Aug 5, 2016
- Messages
- 22
I have newly rebuilt Bendix mags on an O-360 and am using the p-lead "pick-off" method to measure RPM on a SV HDX. 30k resistors are installed near the ignition switch per the manual. This was working fine during the first two mag checks, but on the last engine ground run the RPM dropped to zero for the right mag only. The engine sounds normal and runs smoothly, with an audible RPM drop on the right mag as you would expect. I have checked continuity between the EMS and the ignition switch terminals and end to end on the right and left p-leads; everything looks good. The zero RPM problem was noticed after a brief max power runup to 2200 RPM (we're at 8000'+ density altitude with 3 blade fixed pitch prop). Would that runup have changed something? What else should I check/do?
